I have "installed "all the DirectX downloads I could find, but dxdiag indicates "DirectX 10.0 (4.10.0000.5515)". My "benchmark for updates is C&C TFD, and I get a message to update DirectX and the game will not run. I have been downloading the DirectXupdates to Win 32 DirectX and trying installs from there with no success. Please help!
SOURCE: Office XP sp3 update
SP3 is a huge file approx 320Mb, before to go to Microsoft WEB site to download it, make sure you have sufficient space for the download and sufficient space to install it. If you limited space, remove unnecessary files and do a disk cleanup. After you have downloaded SP3 copy it to a CD, remove the downloaded SP3 and install SP3 from the CD.
SOURCE: HP 6000 no audio output installed
have you solved the problem because i have the same problem and i dont know hoe to fix it
SOURCE: problem installing WLAN card after installing Vista
First rule-of-thumb, don't trust windows updates for drivers. With that being said, you should find out what the chipset of that Atheros card really is. Download a program called Unknown Devices, by Halfdone. Install the program and run it. It will tell you the actual chipset. Then google search that chipset with the words "xp driver" after it. You should also look at the list and see what the bluetooth type is in you laptop. Usually it will be either a Toshiba bluetooth stack, Widcomm, or Microsoft. Then google that with "xp" after it to find the driver for the bluetooth. Install the software and driver and you should be all set.
Let me know if you need more help.
And if this fixed your issue please make sure to leave comments. Thanks.
SOURCE: audio driver install to error for microsoft bus driver HD install
hey download the bus driver first . u can get it from microsofts website i too did the same but i have forgotten the link. sorry find the driver and first install driver for the BUS. then install the audio driver
SOURCE: Acer Aspire 5502ZNWXCi sound driver
Please get it here :
www.nodevice.com/driver/company/ACER/Laptop.html
www.laptopdrivers.net > Acer Laptop Reviews
Jay_G
I checked the status of directx using dxdiag, because C&C FTD will no longer play some of the games in the port folio as " Diectx is not up to date". So I downloaded DirectX 10. 0 and installed same to find it didn't update.
Am I missing a step in this procedure
