I Got the controls to work without an interface, it's a little complicated but if you hook up everything but the swc wire, turn on and go to the swc programming, hold the desired steering wheel button, then as you hold it touch the signal wire to key 1 and pull it back off, do this for each key then set what they are. I did this in my 03 escalade
I called metra about this. Solid brown to key 1. Brown/white to key 2. Black to chassis ground.
What was the outcome of this one? I am having the same issue. I have tried all possibilities with the wires in the back.
SOURCE: KVT-729 car DVD player
The steering remote control input is for a wired remote control, or a third-party interface that allows you to adapt vehicle steering wheel controls to operate your deck. Your problem is the parking sensor wire. This is supposed to be connected to your vehicle's parking brake switch. It detects when the brake is set, and will prevent a picture from showing when it's not set. The intent is to prevent you from watching movies while the vehicle is in motion. If you can get a good look at the parking brake mechanism, you should be able to see the brake switch. Usually there's a single wire coming from the switch, which is built onto the parking brake mechanism. Connect your parking sensor wire to the wire coming from this switch.
SOURCE: Kenwood DDX-514 label wires
90% of new and aftermarket harness' are the same, Red any Yellow are Constant 12v and ACC. 12v. Black is ground, Green is rear left speakers, Purple is the right rear. White is front left and Grey front right. Blue solid is Power Antenna, Blue with a white is an AMP Relay. (Which is another 12v ACC) You should have some sort of AV in/out lines for the rear screens, if that was an issue.
SOURCE: wire diagram i think
pink wire if its to go to ground then any metal is ground or negative not live in other words they say the handbrake so you cant use it whilst driving so any metal should do for this ok.
Are you wiring it to amp or not?
Also the mute only wires into say phone cradle or something that would mute the stereo say if you had phone in craddle this would mute the sound so you could here the call. so not needed unless you have phone craddle.
If the two lives are wired in and the ground black when you earth the pink then it should switch on let me know if this happens.
Auto ant is for the arial on car if this goes up and down on motor if not then its not needed
Ill check on dimmer/illumination ok but bare with me for couple of hours just popping out but will get back to you then ok
SOURCE: Farenheit DVD-36 Car DVD need wiring diagram please
USUALLY THE BLACK IS ALWAYS GROUND AND THE RED CARRIES THE FUSE. IF IT DOES NOT SOLVE YOUR PROBLEM I GUESS YOU WILL HAVE TO TAKE IT TO A TECHNICIAN .THANK YOU.
What was the outcome of this one? I am having the same issue. I have tried all possiblities with the wires in the back.
How do you connect the wire part of the axxess swc to the aftermarket radio, boss bcpa10? This one has the headphone jack in the back?? What do I do??
