20 Most Recent
Boss BV9250 Car Video Player Questions & Answers
Replacement remote boss audio dvd 7500
If original remote is not available, you can use Universal Remote Control for your product but Universal Remote Control will require programming for your product.
I have a 3000 watt Boss mono block amp that is stuck in protection mode and green light is flashing any ideas on how to fix it plz
It's a inexpensive amp, and poorly made. the amplifier failed. you won't be able to fix it unless you open it up and happen to have a degree in electrical engineering, or have the schematics to that particular amp and access to the parts like the transistors/finals and power supply bits to replace the damaged parts. chances are you blew mosfet(s) in that case the amp is a paperweight.
Sorry for the bad news. I had a couple of Boss amps and after second one fried went with another brand. Ck out amps on Azon.
Best to you.
I have a used boss audio BB8 and need to install in my 2010 gmc sierra denali.
It's possible that the Boss Audio BB8 unit may work without the remote control dial, but it's best to check the manual or contact the manufacturer to be sure.
As for the RCA outputs, it's best to use an RCA output if your stock tuner does not have RCA outputs. You can either purchase the harness for high input or the variable LOC and convert it to RCA. However, the best option for you depends on the specific requirements of your system and the compatibility of the equipment. It's always a good idea consult the manual before making any changes to your car audio system.
Where can I get a replacement harness for a Boss BV9967B the plug that goes in the back of the head unit for power and speakers
You may be able to find a replacement harness for the Boss BV9967B at an electronics store or online retailer. Some options for purchasing a replacement harness include checking with the manufacturer, contacting a Boss dealer or distributor, or searching online marketplaces such as Amazon or eBay.
You may also be able to find a universal wiring harness that can be used with the Boss BV9967B. These types of harnesses are designed to be compatible with a variety of head units and can often be used as a replacement for a specific manufacturer's harness.
It is important to make sure that you purchase a wiring harness that is compatible with the Boss BV9967B and the specific vehicle in which it will be installed. Make sure to check the fitment information and any applicable compatibility notes before making a purchase.
How do you remove a stuck cd on a boss mp3-3030r?
Refer to the following link: https://www.manualslib.com/manual/423496/Boss-Audio-Systems-Cd-3030r.html?page=4#manual. Page 4 remove head unit. Disassemble head unit to determine what is jamming he CD.
I have a Boss BV6656B and I can't get my Bluetooth to connect, the SRC only displays Radio and AUX?
Page 9 of the manual says it goes into Bluetooth Search when you power it on, so get your phone searching and then power the radio on. Pretty much every Bluetooth unit I have come across needs a button pressed to send out the signal.https://www.bossaudio.com/manual/BV6656B_EN_UM.PDFI don't like this mention of a 'Hands Free Kit' or that is says 'pairs to *most* mobile phones'.Bluetooth Features:Built-in Bluetooth technology for hands-free talking and audio streamingBluetooth Profiles Supported:HFP: Hands Free Profile allows a hands-free car kit to connect to a compatible mobile phoneA2DP: Advanced Audio Distribution Profile allows high quality audio to be streamed from an audio device to the car stereoWorks with most Bluetooth enabled cell phonesIncludes a built-in microphone for clear, convenient, distortion-free talking..
