Car Audio & Video Logo
Posted on Mar 22, 2009
2005 Toyota Camry JBL Radio Replacement: Info button issue
I have a 2005 Camry with (I believe) the factory installed six speaker JBL system. I want(need, actually since the CD player is shot) to replace it with a aftermarket Kenwood with BT, iPod control, etc. However, Crutchfield warnsthat the ''Info'' button on the steering wheel will no longer activatethe trip computer if the radio is not the factory one. (I'm guessingthat all of the buttons from the steering wheel (volume up/dwn, etc,along with ''info'') route through the radio harness.) A simple test: Ihave the radio out of the car now, and the Info button does not work.
Does anyone know a workaround? Can someone post the wiring diagram for the 2005 Camry with 6 speaker JBL system, 4 door coupe? Does anyone sell an aftermarket wiring harness that allows the ''info'' button to work?
I would be most appreciative ... I have the car torn apart and need to resolve this.
Thanks for this forum ... very helpful,
DZ
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 18, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2807
Points
Crutchfield sells an aftermarket kit that allows the steering wheel controls to work, but it's $74, and you head unit must be remote control capable. They also sell a wiring harness that works with Kenwood/Toyota as long as you have the original wiring harness that came with the Kenwoood. You'll need to do some snipping and krimping however.
Need 08 Toyota Camry wiring diagram for factory stereo with jbl amp
https://www.modifiedlife.com/2008-toyota-camry-radio-wiring-guide-2/
2003 Toyota Camry jbl amp wiring diagram
In the links
2003 Toyota Camry Car Audio Wiring Diagram - MODIFIEDLIFE
MODIFIEDLIFE https://www.modifiedlife.com > 2003-toyota-camry-ca...
Our 2003 Toyota Camry radio wiring diagram shows you all the 2003 Toyota Camry radio wire colors and what they do. Use our 2003 Toyota Camry stereo wiring guide ...
Toyota Camry SE 2003 - SYSTEM WIRING DIAGRAMS
Automotive Electricians Portal https://portal-diagnostov.com > 2020/05/02 > radio-to...
May 2, 2020 - RADIO - Toyota Camry SE 2003 - SYSTEM WIRING DIAGRAMS Radio Wiring Diagram, with Built-in Amplifier. Get Access all wiring diagrams car.
Over my head! Radio wiring 2003 Camry - Toyota Nation Forum
Toyota Nation Forum https://www.toyotanation.com > threads > over-my-he...
Jun 4, 2017 - The only difference between the Gen4 to Gen5 JBL harness that I know is there is an additional wire that comes from the car harness to the amp.
Wiring diagram for 2001 Toyota Camry LE with JBL speakers
https://www.modifiedlife.com/2001-toyota-camry-radio-wiring-diagram/
2answers
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
4helpful
Need a wiring diagram for a 2003 toyota camry with jbl audio system
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
pls rate
I installed a sony x plode amp in a 2005 corolla which had a stock six speaker amp by jbl which came with car i also bought a jensen hd dvd radio i installed radio but need a wiring schematic to by pass...
If I am going to have a car and do a lot of audio installations, I try and order the manual for it. The manual usually has a full wiring schematic. You might call down to your local Toyota dealership and see if they can help you with the wiring schematic.
Also, you could just run new speaker wires. I know its a pain, but that is another alternative. With that being a newer car though I can understand not wanting to start tearing off internal moldings.
Text button does not work
When you insert a cd that has folders of MP3's it's suppose to display the music info., IE., artist, album,
2006 toyota camry JBL radio; controls don't work
THIS IS A RADIO PROBLEM, THIS PROBLEM WILL REQUIRE THE RADIO BEING SENT OUT TO AN AUTHORIZED FACTORY ELECTRONICS REPAIR CENTER, THERE IS NO BLOWN FUSE OR THE RADIO WOULD NOT EVEN TURN ON.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
