HELLO
the plasma therns on with some noise from the power supply.
the pictcher is good but if i move the INPUT to another the plasma therns OFF and the led blinks 5 tims.
Could be the fans. Your bright setting may cause the plasma to get hot causing the fans to turn on. If the buzzing noise is coming from your speakers it could be bad wires or bad directv receiver.
Turn the brightness level down and the noise wld be subsided.................
And regarding 5 blinks............
U knw wat each blink refers to a certain indication...........
Download the pdf file, It shows the reason for 5 blinks ( It refers to defective board )............
Read hoe to go about this issue :)
http://www.pasctraining.panasonic.com/pass/elearn/files/Plasma/070608_10th_Gen_FlowCharts_070607-P.pdf
***************Do Rate This Post*****************
Dear Sir/Madam,
5 red LED blink problem with a singing power supply. Turning on and off, normally twice. Try hard reset.
Most likely the SC board. Sometimes an SU or SD will go bad and take
out the SC as well so carefully check the surface mount ICs on the SU
and SD for small cracks, bubbles, or other signs of overheating.
Be careful if you choose to look at this yourself.
Thanks
good luck
You are talking about tv right
Unplug the power cord for 3 hours. This will totally discharge the
internal eproms and empty out any old memory data. When you power
back up it will reset to factory defaults
A possible loose wire connections / signal have result the problem.
check the connections.
HI
i dont andertennd you....
all the plugs see OK !
also'
the green LHGIT DONT APEER in the front of the panel.
please
give me an unswer.
thenks
meir.
HI
I DID THAT YRSTERDAY
ITS THE SAME PROBLEM
