SOURCE: Not sure whether Athiros is the driver for WLAN ACER ASPIRE 4730Z
Here is the link for all drivers for your Laptop XP/Vista: Try all this drivers
WLAN_Broadcom_V4.170.25.19 Driver for Aspire 4730 4730Z Win XP
WLAN_Intel Shirley Peak_V12.0.0.78 Driver for Aspire 4730 4730Z Win XP
WLAN_Ralink_V1.1.5.0 Driver for Aspire 4730 4730Z Win XP
WLAN_Atheros_V7.6.0.239Driver for Aspire 4730 4730Z XP
http://komku.blogspot.com/2008/10/aspire-4730-4730z-windows-xp-and-vista.html
SOURCE: HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Testimonial: "Thanxs"
SOURCE: How do I hook up my Acer Aspire laptop to my Epson
You can hook up Acer Aspire to your Epson Printer Using the USB Port if the printer supports the USB port A type. I am not sure what model of Epson printer you are using. You may have to configure the printer either by going into add remove hardware and scanning for hardware changes and installing the Printer, or may have to put the Driver CD provided to you by the driver manufacturing company and install the driver which will also allow you to print a test page at the end of installation to give you a clear picture that the installation was successfull. Please ensure that the printer is connected to the laptop and is powered on while giving for a test print. Good Luck.
SOURCE: I have an acer aspire 5535-6637 and I was
i have an acer aspire 5535-6637 and it does not have an s-video port on it. only VGA.
SOURCE: Hi, I need help with
Hi
can you please check that the touchpad has not been locked i dont think it has but worth a try
by pressing FN+F7 or FN+F9
also check that the nulock has not been ingaged by mistake
also the scroll lock
or go to
start
all programs
acer
acer management
contents
scroll down to find the touchpad/pointing device
go over to the right by the green icon and hit the install tab
and let windows re install the touchpad
may be this will help
many thanks
THANKS IL BUY IT THEN AND THEY ARE PROVIDING THE CABLE..JUST WANTED TO CHECK FIRST BEFORE I PURCHASE..THANKS
