There is a tubular piece of plastic inside the analog stick that probably snapped. open up your controller and you'll find that the peice of plastic is hollow. to fix this, cut up some paper clips to the right size and cram them in the hollow space for more stability. superglue the plastic peices together. hope this works for ya.
thumbs up if helpful :)
Mine did the same thing. buy a new one
Hello alsupjonatha,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
