Watches Logo
Posted on Nov 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DNKY Watch Stem
The stem came off my watch and will not go back on. Please advise.
Anonymous
Level 2:
Champion:
  • Expert 203 Answers
  • Posted on Nov 21, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
203
Questions
Helped
103117
Points
421
Did the whole bar come out? joe
I have a Westclox W3 manual wind up wrist watch that I need to remove the stem on how do I do
Removing the stem on a manual wind-up wrist watch can be a delicate task, as it requires some knowledge of watch mechanics. Here are the general steps to remove the stem on a Westclox W3 manual wind-up wrist watch:
  1. Make sure that the watch is not wound.
  2. Use a small screwdriver to remove the crown from the watch. This is typically done by gently pressing down on the crown and twisting it counterclockwise.
  3. Once the crown is removed, you should be able to see the stem.
  4. Use a stem removal tool to push the stem out of the movement. A stem removal tool is a specialized tool that is designed to remove stems from watches, it can be found in most watch repair kits.
  5. Carefully remove the stem from the movement.
  6. Once the stem is removed, you should be able to access the movement of the watch for repairs or maintenance.
Jan 24, 2023 • The Watches
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
1helpful
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Stem is loose and water got inside
You could try removing the back and allow it to dry out but you may still have the loose stem problem.
I advise you to take it to a watch repairer and let them dry it out and sort out the loose stem.
Feb 07, 2010 • Watches
1helpful
Stem of watch won't return to its original position
The winding crown is loose on the stem. Get the stem completely out of watch and while holding in vice or pair of pliers screw the crown back on tight. Do not overscrew it, as the stem may brake. Even better would be to unscrew the crown first, dip the threaded stem end in to the Superglue and then screw the crown back. It will prevent from the same problem in future.
Rate, please.
Jul 29, 2009 • Watches
3helpful
I pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Mar 24, 2009 • Watches
12helpful
2answers
Removing the crown/stem of CASIO EF-321
Other case for a simple Casio quartz watch :
7answers
I have a pre-owned but mint condition 18K two-tone Cartier Panther watch with the date in the 5'o'clock position. The date currently reads the 18th, but today is the 11th. Is it safe to pull out the stem...
hello,
first give the answer carefully
is you have a problem to set your clock.......
if yes..
then watch these video and tell me is you have the same problem
IF ANY DOUBT
contact me
Not running
look for a tiny, clear plastic spacer washer on the stem and remove it. this is just thick enough to prevent the stem from being pushed all the way in. this is factory placed to prevent inadvertent turn on during shipping.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
