How do I program speed dial?
SOURCE: Canon Super G3 Copy Fax Scan
I gave up on it. I was able to disassemble it and get to the power supply PCB but the main fuse was not blown. A new power supply PCB was too expensive and I don't have time to troubleshoot the power supply. Thanks
dewberr
SOURCE: Canon Super G3 MF5770
how did you do that? and what tiny piece are you talking of? I can not seem to get the alarm to stop blinking "check document".
SOURCE: Canon super G3 that use 1TU-TV34 standard 33.6Kbps modems
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: i need a manual instructions for my canon printer(super G3)
Go to:
http://www.canon.co.uk/Support/
find you printer and download user manual.
Derek.
SOURCE: I want to connect my canon super g3 to my inspiron
You will need a parallel cable and the correct driver.
