20 Most Recent
Canon LaserCLASS 3170 All-In-One Printer Questions & Answers
3170 printer error code e000748-4000
I think you will find a good answer here:
threadby
canonteckE744, means that Language file/BootROM error.
You
need to upgrade the DC controller PCB version, wich is done over
service support tool. That means that you cant do it on your own, call
service.
Supply Rec. Paper message keeps
Hello there,
Unplug the printer, and wait about 1-2 minutes. Plug the printer back in. Wait until it is finished resetting itself. If the paper light is still flashing, the sensor inside may need to be adjusted, as it may not be detecting the paper.
Also, make sure there is no paper jammed up in the rollers inside. Even the smallest piece may cause this light to stay on.
Also, make sure there is not too much paper that it would no be able to feed the paper through in an attempt to print a document or photo etc.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
How to forward an incoming fax to another number
Do you have the device connected to your network? If so, you can go to it's web management interface by entering it's IP address into your web browser's url bar. You will want to look under Add. Func., Fax Forwarding.
I do not have a
You don’t specify which operating system you have on your computer;therefore I give you this page, to select the driver to your OS.If you incounter problems with the "new" PCL6 driver, then try the "older" PCL5.
plz let me know how it goes.
Regards/Teis
