40. (00101000) Bowl Dis-engage Fault
While carrying out a bowl check, the Motor Control Module has found that the bowl is not
engaged even though the pressure sensor indicates that the bowl is empty. The Motor
Control Module continues to check for 2 minutes, after which time it displays this fault. The
first two areas to check are the clutch and the pressure tube. If these two appear correct,
then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing
the clutch from re-engaging. Excessive suds can stop the bowl
rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
