I have a samsung LE40M86BD LCD TV, When you use the sky planner or when there has been headline...
(More)
I have a samsung LE40M86BD LCD TV, When you use the sky planner or when there has been headline writing on a tv station that you are viewing and you switch channels you can still see the sky planner or headline writing behind the new programme that you have switched too
I have a 14" Phillips flat screen LCD TV. this is fine when the weather is warm but as it gets...
(More)
I have a 14" Phillips flat screen LCD TV. this is fine when the weather is warm but as it gets colder, the delay between switch on either by direct buttons or by remote, can be 5 to 10 minutes before the picture appears. Can anything be done about this?
when I turn on my 40 inch lcd samsung tv the sound works but the screen wont start up and the red...
(More)
when I turn on my 40 inch lcd samsung tv the sound works but the screen wont start up and the red power light flashes
LE40R73BD SCART AND AVI INPUTS PRODUCE A REDDISH / PINK COLOURED PICTURE, HDMI AND NORMAL TV PICTURE...
(More)
LE40R73BD SCART AND AVI INPUTS PRODUCE A REDDISH / PINK COLOURED PICTURE, HDMI AND NORMAL TV PICTURE COLOUR FINE . ANY HELP APPRECIATED ???? HAVE TRIED FACTORY RESET. DVD VIA SCART WHITE IS PINK DVD VIA HDMI WHITE IS WHITE .
losing top of heads on tv samsung 40 inch lcd seams to be like zoomed in .i have just repaired the...
(More)
losing top of heads on tv samsung 40 inch lcd seams to be like zoomed in .i have just repaired the mains bord but come to think it seaned like that befor
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
