Is this something that is cost effective to get repaired?
Usually this is caused by putting the card in sideways. you can usually see if pins are bent or pushed through (loose floating around inside) and you see an empty black rectangle where the pin should be.
pins are soldered to main circuit, and the XTi uses lead free solder which requires skill to repair. this is repairable but would run you somewhere in the $150-190 range
SOURCE: Canon EOS 400D
The camera is working again. I took out the battery, with the the on/off switch, off. I then swtiched the On/Off switch On. I then put the battery in ,and the camera turned on.It then gave me an ERROR 99. I then switch it off and on again, and it is still working.
SOURCE: Canon EOS 400D LCD screen problem
There is no live preview mode on this camera. I am not sure if that is what you are referring to, but you can only use LCD for review and menu, not as a viewfinder.
The new Rebel XSi is the only one in the rebel series with this new feature.
Hope this helps!
SOURCE: canon eos 400d. card empty but cf light flashes red
Hi! Rachel, Mark here see if i can help.
Try different cf card see if it works.
Next if that worked or not take cf card place in computer & format card. Retry in camera.
Hope that fixed ya if not comment back me happy to assist you further. Good Luck! please rate.
SOURCE: I would like to download a copy of a canon eos 400d manual in eng
Here's how to do it:
Go to this page: Canon Digital Rebel XTi
Click Drivers & Downloads, scroll all the way to the bottom, and click on the PDF link as shown.
EOS DIGITAL REBEL XTi / EOS 400D
DIGITAL Instruction Manual
EOSDRXTi400DIM-EN.pdf
Have tried this and also tried other cards in the camera. Suspect one of the tiny metal prongs that the card fits over when loading it is out of line so the connection is incomplete. Has anyone else had problems in this respect and is it an expensive repair?
