Hard drive replaced and I need to know how to boot it up
You need a system disk first of all. Put the disk in the drive, turn the computer off then reboot. Watch the screen for which key it says to hit to change the boot sequence or boot order. Hit that key when it is shown. This is a one time solution that is only for the current boot process.
To make it permanent, boot the computer an notice what keys it says to hit to get into the Bios or System Setup. Hit that key when shown. You can change the boot sequence or boot order and make it a permanent change in the bios. The most common and best boot sequence is to have the CD drive 1st and the Hard Drive 2nd. Just make sure no disk is in the cd drive when you boot it up or you will get a error saying no boot record or system disk found.
SOURCE: compaq evo n800 laptop built-in wireless internet
right click "my computer", left click properties, select "Device Manager" Expand anything to do with "Network Adapters" and make sure there are no problems / exclamation marks / unknown devices.
If there are, look for your wireless driver on..
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=compaq+evo+n800&submit=Go+%C2%BB
depending on your model. if this doesn't work go to www.hp.co.uk and download the driver then install it.
If you can't detect any wireless networks, make sure your wireless card is activated - I believe this involves holding down FN (bottom left of keyboard) while then pressing F2 key at top. after this try try to search for wirless access points points.
Good Luck,
Cheers,
Colin
SOURCE: non system disk or disk
Yes. Your laptop is far worth fixing. If you can do it yourself, open the back cover where your hard drive exists to make sure it did not get out of position (Probably due to shock during travel)
Then using a windows xp installation cd, run the laptop from the cd and when the setup screen reaches the point of "pressing enter to continue installation, or "C" for a recovery, pre C to go to the DOS prompt screen. On that screen, use the command >CHKDSK and press enter..
It should detect to disk and fix it for you. If it wont detect the disk, then probably you damaged it and need to replace it. You will have to go to a store to purchase one.
