SOURCE: pfaff sewing machine
You don't have the thread in the take up lever or it is not in the tension. Rethread it , Pull the thread through the tension assembly and
test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way. set your tension to 5 and try it.
sewman7
SOURCE: needle cannot be secured in PFAFF 1222 sowing
Well if you stripped it then there is no magic fix for it except to replace it. It's pretty hard finding the correct tap fixing the stripped threads.
