If you are using hibernation mode it causes all kinds of problems, not working, corrupting window files so you are forced to do a fresh install. The reason is windows needs to be properly shut down, other wise it will become unstable to the point you won't be able to access files. I strongly reommend to disable this function or at the very least make a backup recovery disc.
SOURCE: Fn+F4 on HP laptop does not toggle
s video is output for the tv and its not controlled whith those buttons that you have to configure in the graphics drivers, but usualy the s video on hp and compaq laptops quit working but you have to configure them in the graphics driver
SOURCE: I don't know what fn f4 or fn f8 do.
Laptop keyboards can differ with the function keys and are set out different depending on make and model.
If you take a look at the F4 and F8 keys, is there any symbols (in blue) on them? If there is post back here with a description of the symbols, If there is no blue symbols on the keys then they will do nothing and there is nothing to worry about.
Regards.
SOURCE: I have a hp pavillion dv2315nr laptop with a black
when you power up the press F8 key then enter in enable vga mode then go to control panel ->display ->settings ->change screen resolution to 1024*768 then apply and ok then restart .
Thanks for using fixya.
Please rate solution if it helps.
SOURCE: i just purchased a sylvania meso netbook..8.9"
Hi
Have you checked that the wireless switch has been switched on it should be visable somewhere on or around the key board or on the front or side of the laptop some you have to press and some you have to slide to activate it
