MY SYSTEM NOT YET PROPERLY TURN OFF TILL THE DATE OF PURCHASING .......I M SWITCHING IT OFF IN BETWEEN THE PERIOD OF RESTART .............IS THERE IS ANY OTHER SOLUTION .....
its an paid app
try to install a trial version
and run in the trial period only
after trial period expire
reset your system timing in that period only
eg:
you activated trial version on 01/01/2014
valid for one month
then after every month as date become30/01/2014
set your date back to 01/01/2014
your divx will work but system will show wrong date
and you cant run opera or web
check in safe mode. how?
shut the computer off//
cont hit f-8 key immediately you restart the computer. keep tapping f 8 till you get advance boot option.
make sure you connect the internet directly to the computer means remove the wireless connection if there is and hook it wired.
select safe mode with networking and login
check the internet and if it doesnot work then do system restore to prev date when the computer was working fine.
always make sure that the date selection should be sufficient if you are not sure.
selecting the date doesnot alter anything on the computer.
follow the wizard of system restore and the computer will restart automatically to normal mode.
if your security suite is not opening then you will have to uninstall it from prog and feature and get it installed properly..
You need to run the windows in safe mode.
Shut the computer down wait for 30 secs turn it back on Tap on the F8 key few times then you will see windows advance option then select safe mode using the arrow keys then proceeed to the windows in safe mode. Once you are in windows run a system restore to a back date when it was working fine. To go into system restore tool click on start select accessories and the system tools and then system restore.
Select restore my computer to an earlier time and click the date in the calender box once highlighted hit next and wait till the process completes once completed it will restart the system automatically and will give you a message your computer was restored successfully in case it says not restored then you can select another Bold date i mean a previous date to retry again.
you can run system restore which will bring the computer back to an earlier time lets say few days back with the help of selecting the date in the calender in the system restore tool.
Please press the f8 key on restarting the system on the gateway logo and see if you are able to reach the windows advanced menu screen that shows the safe mode option.
if yes please selct safe mode and then please restore the system to the earliest back date maybe 2-3 days back.
lick Start click allprograms select accessories click system tools and then system restore, use the option restore my computer to an earlier time and you need to clik on the date which is bold in color i mean a back date then hit next to proceed.
wait till it restart and completes the system restore
if this has been a recent problem...try restoring the system to a back date.
boot to safe mode by pressing f8 key on initial dell logo on startup.
plzzzzzzzzzz help me
