I have lost the instructions for my bush cmc22dab music system and cannot save the preset radio stations can anyone help
Try to downlaod the user manual to your set from internet. If you feel any difficulty in downloading, send your email address to me by fieya. I'll send a copy of the manual to you by return mail. It will have all the details.
my e-mail is [email protected]. Please send me the manual. I have tried downloading it, but the links do not work.
Thanks for your help
SOURCE: kenwood KDC-W312S wont keep the saved channels after car restart
Check the yellow wire connection on your wiring harness... This is the wire that provides continuous power even when the ignition is off. This is how the radio remembers presets/time and such. Every time you turn off the car, the radio "resets" because you dont have the yellow wire connected to an ALWAYS HOT wire.
If you cannot find a hot wire, then you can run a wire from the yellow on the back of your radio directly to the positive terminal on your battery. Dont worry, it doesnt draw enough power to run your battery down.
Most cars have a cigarette lighter or power port somewhere that is always hot. You could always run the yellow wire off of one of these.
Just find a way to get the yellow wire on a hot wire and your stereo will remember the presets.
Testimonial: "Thanks. Excellent advice. very helpful"
SOURCE: Help with storing radio stations
Ergh, you might want to explain what KIND of system it is if you need help!
Usually if you have a PRESET button on your system, just tune to the station you want, hold the preset button and it will save the station...or ask you which slot to use (use fast forward/rewind or any other arrow key to change the slot) and viola! And if you have numbers (like in a car for example) just tune to the station and press and hold (for example) the 1 button and it will store the station.
Hope it helps a bit.
SOURCE: manual for panasonic stereo SA-AK40
Here is the manual:
http://service.us.panasonic.com/OPERMANPDF/SAAX540.PDF
There is also other information available on the Panasonic support website. Search by model number on the Home Theater support page.
SOURCE: LG LX-M240 operating instructions: I cannot set the presets
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Stations on presets 1, 2 and 3 take longer to 'kick in' when listening to the radio
as they are the 'tens' prefix for the preset numbers. 4 - 9 'kick in' immediately.
plug it and with power on but don't turn the station on, leave it in standby mode. then press and hold mem/set on your remote. then set the hour and press mem/set to move onto the minutes. when done press mem/set again and your time is sorted.
Can you add where I can find a download of this manual. I have found one link but it does not work
