You rock! Interestingly, I turned the machine around to begin following your directions and that entire backpanel was askew. I just clicked it into it's proper position and ....voila- fixed!
Thank you for your impressively fast response too! You rock! Interestingly, I turned the machine around to begin following your directions and that entire backpanel was askew. I just clicked it into it's proper position and ....voila- fixed!
You can't post conmments that contain an email address.
Use the arrow keys to select Tools and then press the OK button.
Select Clean Print Cartridge and then press OK . The device prints a test page.
Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
Open the Printer Toolbox . There are two ways to do this:
Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
Remove and re-insert, while the product is switched on.
The back of the unit has a piece which pulls off to clear paper jams. It was not fully pushed in. I found the solution on another post that was on your site.
Sounds like the print head / ink cartridge is not seated all the way. Open the door and check it. It also may be the wrong print head / ink cartridge. If you replaced the print head / ink cartridge recently, you may have the wrong one for your device. If it is a off brand or refilled print head / ink cartridge it may be damaged or incorrectly identified.
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
please check gear train and confirm no broken one-check of selonid not working in a right way and no foreign object droped inside(like pins).-check of smoth actuation of paper present detector.(in place and movement when you put papers
