I can't even choose to go into safe mode or anything, it's just a blank (grey) screen. Everything sounds like it's running, but the screen wont work. Before, I would just plug it into the monitor and when it's booting press Fn F8, but even that isn't working. How do I fix it?
Check your hardware light on the exterior of your computer and see if it is lit and blinking. If it is, you have an operating system, but just can't see it. That tells me it may be several things:
1. The LCD cutoff switch is in the off position
2. Toggle (Fn) the display to the internal settings of the LCD panel. It may be set to display an external monitor only
3. Plug in an external monitor. If it doesn't display on the external, after pressing the Fn key you have a failed video adapter. If it does display on the external it is most likely a back light or inverter failure.
SOURCE: dell insperon 9300 wont boot even in safe mode
sounds like board problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
SOURCE: Dell Latitude c640 wont boot in normal but will
Check the device manager to check if all your devices are working properly.
SOURCE: window wont boot on dell latitude d610, system
there could be a posibility that the harddrive of the laptop is damage and needs to be replace. you already tried to reinstall the operating system but it still wont work in that case try to replace your harddrive.
SOURCE: Dell latitude d630 won't boot up.
Can you boot in a Safe Mode with no problem? If you can try to use System Restore to return Laptop to previous state. Go Start----->All Programs------>Accessories----->System Tools-----> System Restore It's easy to use and it may return your system to time when it worked properly. Good Luck!
Well, I took it to the shop, they took everything apart and put it back together. Then I asked them to delete everything. Works fine now, thanks though =)
