The oil filter is underneath the bike in the front where the large square gray oil pan is located. There are two bolts. One is surrounded by a large circle which is about the size of your new oil filter. Remove the bolt and there will be a small washer then the circular metal plate which cups the oil filter. This has a gasket which seals against leaks and inside of the cupped metal plate is the oil filter. Remove replace, and reinstall the parts in the same order. ,,,
Question edited for clarity. I am sure hard acceleration causes 'exhilaration', but it was the wrong word.
Second gear put the most strain on the clutch for the longest time. First gear is a short shift with the highest torque, second gear is a longer shift but only with marginally less torque. Either the clutch is badly adjusted or the clutch plates and springs need changing.
https://www.manualslib.com > ... > Service manual
KYMCO Venox 250 Manual Online: right crankcase cover removal, One Way Clutch Removal. Drain The Engine Oil. Disconnect The Clutch Cable. Remove The Right ...
To change your oil filter remove oil drain plug drain oil into an oil pan clean and replace oil drain plug, then remove oil filter, pour a drop of clean oil onto a new oil filter, and lube gasket, then replace the old oil filter with the new oil filter. Finally, add clean oil to the motorcycle until the oil level window shows oil in the middle of the viewing window when the bike is upright. ,,,
HOW TO REMOVE SEAT TO GET TO BATTERY
