I believe the bowl was put on incorrectly and is now locked. I don't want to force it. The cover will come off, but the bowl itself only turns about 1/8 of a turn (45 degrees). Is there a way to get it to release?
SOURCE: Kitchenaid Food Processor - Center Stem Support doesn't turn
Grease, it needs grease to lube it.
SOURCE: my kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Never mind. I've gotten it off. I was able to carefully turn the bowl past the "catches" where the bowl sits on the base to a position where the center opening of the bowl was free of the "notches" in the center post. Bowl came free from base and I was able to position it on correctly.
