SOURCE: it powers up....no modulation ...output power..or
Sounds like the PLL may be toast. Either that, or someone has **** with the wrong potentiometers or tuning slugs in the radio, causing to to no longer resonate on the correct freqs.
SOURCE: galaxy 949 mobile CB is off frequency when
a friend of mine just told me he used the galaxy 2517 adjustment procedures. I hope this may help you. Buckeye back quiet.
SOURCE: Galaxy 949 Receive problem
this sounds as the osolator has moved of freq. to check this you need to put it on a scope
SOURCE: how to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods
DX 2527 -
VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range,
VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF
Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC,
VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC
2....10.240.
DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB
Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR
6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR
9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver
Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation
Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power,
VR601..13.8 Volt Power Supply.
DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB
Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier
Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC,
VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low
Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240.
DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR
3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM
Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final
Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power,
VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias,
VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low
Power.
DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR
2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch
Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF
Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC,
VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power,
VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only.
DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM
S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF
Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power,
VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only)
DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR
3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier
Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias,
VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM
Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low
Power, VC1....10.240.
DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power
2SB817 100 Watt 12A. Derating of this component will cool operation,
provide better voltage stability,decrease wobble, allow voltage
increase to 14.5 volts comfortably. (replace 10 volt caps in this
section of the radio to a minimum of 16 volts before increasing supply
voltage to this level)and provide faster swing rise time, Replace Q37
2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and
volume of the modulation and it will also run a lot cooler.
SOURCE: got a galaxy dx 949 mobile trying to wire a older
Hello twelch,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
If it is the old four(4) wire mic, the wiring will be as follows:
Pin #1. Shield (Ground)
Pin #2. White (Audio)
Pin #3. Red (Transmit)
Pin #4. Black (Recieve)
If it is a SIX (6) wire! The Blue would go to Pin #1. with the Shield, and the Yellow
has no connection. I hope this was helpful to you. Your Comments and Testimony's are
always welcome here at FixYa. Thanks for choosing FixYa today and in the future.
John
Testimonial: "thanks john for the help"
