I UPGRADED AND NOW CANT OPEN FILES OR FOLDERS ITS LIKE HARD DRIVE IS BLANK WONT READ RECOVERY DISK
What do you mean you can't open files or folders? Are you saying the files or folders are not on the hard drive since it's blank? I think you've got a virus that has hidden your files and folders?
I'm not sure which operating system you have but you need to get to Folder Options.
In Windows XP you can click Start/My Computer. When My Computer Opens click Tools at the top of the window and then select Folder Options. When the Folder Options window opens, click the View Tab and scroll down and select Show All Hidden Files And Folders. Click OK then go click on your C: Local Drive and see if your folders and files are there. Hidden Folders will show up lighter than a normal folder.
SOURCE: K17A Pioneer DVD-RW - Won't recognize blank CD
Then might have a problem,if is it still in warranty you should return it to your dealer(have you tried formatted the blank cd first?many programs such nero or alcohol gives that option)
SOURCE: Toshiba L300 - disk drive tray wont open
Take a sharp object like needle and insert into the hole below the eject button...
SOURCE: i have a toshiba satellite A105 s4244 and i think
Try starting the computer is safe mode networking mode by restarting and at the same time pressing F8 key
and run virus scan online
http://safety.live.com
SOURCE: NO HDD RECOVERY AREA !
first boot pc, then right before windows would start, press either F2 or F8,, I think it's F2, this will bring you to bios settings, look for bootup device options, Set cd-rom as first bootup device, then Hard drive as second device, Then save settings, insert recover cd, then restart pc, it will immediately boot up your recover cd or windows disc
SOURCE: i have Dell inspiron 1525
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
Testimonial: "thanks for your reply its very helpful"
