SOURCE: how do i reset or remove build-in HDD user
if you are talking about the user password that prompts you when you log in to windows...(and you do not know it ) just reinstall the password...if you know the password and want to remove it ...go to control panel ...user accounts ..press the admin account you are logged in ...and after that click remove password...
But I repeat ..if it is the user password and you do not know it ..and it boots until the password prompt in windows...than the only options is to reinstall ...If you have another user with admin rights on it ..you can remove the other account from user accounts also ...
SOURCE: HDD password for Toshiba Satellite 1400
You get 3 attempts,if after which you have'nt got it right you need to shut it down and try again. But the easiest way is to contact Toshiba,Because if the laptop is genuinely yours you would have registered it when you bought it!!, if you did'nt then your stuck in a sticky place,like when Sticky the stick insect got stuck on a sticky bun!! Basically you will have to prove that you are the rightful owner i.e. Proof of purchase
SOURCE: Built in HDD Password for Toshiba Portege S100-S1133
remove the rtc battery it's look like a bateery on the organizer its round and flat remove it then disconnect to remove the password
SOURCE: How to unlock hdd/ssd password on toshiba
Step 1Turn on your laptop. Press the "F2" key when the first loading screen appears. This will load the BIOS. You'll only have a second or two to press this key before Windows begins to boot. If you're not fast enough and the Windows screen comes up, simply restart and try again.
Step 2Use the right-arrow key to highlight the "Security" tab. This is the third tab from the right.
Step 3Press the down-arrow to enter the Security Settings menu. Scroll down to "User Password," listed beneath the "HDD/SSD Password Select." This will open a pop-up window with three text fields.
Step 4Type your current password into the "Current Password" field. Press "Enter." Type your new password into the "New Password" field and press "Enter." Type the same password again into the "Confirm New Password" field and press "Enter." The "Password" window will close.
Step 5Press the "F10" key to save your new settings and exit the BIOS. Your laptop will now boot normally.
Tips & WarningsHDD password can be changed as many times as necessary. However, once you enable password protection, you can never delete it.
SOURCE: Unlock hdd/ssd password on toshiba satellite
TipHDD password can be changed as many times as necessary. However, once you enable password protection, you can never delete it.
