The remotes dont work so now you cant get into the service menu and crank up the horizontal width thats because the micro no longer has eerom memory to correct the deflection circuits two possible causes a chip resistor ( i forget the value in the front of the pcb and on bottom is open and not supplying dc to the remote reciever and/or the eerom its been a while since i saw that problem
Something is going bad in the horizontal deflection circuit,you should not have to adjust at all,if this part fails (possibly a capacitor)all the way is goin to take the output transistor and a fuse ,I suggest you call for assistance now before it gets worst.As for the remote you can find it in Google.com,just put the model number of the tv and the word remote and all the information you need will show up.If you are familiar with tv service you want to take a look for overheated components close to the flyback but if you are not too familiar be safe and ask for help.
I'm pretty mechanicly inclined. Is this something I can get the part and replace?
Also the remote is OK. I have 2 remotes that workes on the TV and both stopped working at the same time. There are times I can get the original remote to work for about 10 seconds after the TV is turned on manualy to adjust volume but will not turn the TV on or off.
Thanks Again for the input. :-)
I did not get any responce On if I can get the part and replace it my self. If this is something I can do where would I get this part? Who should I talk to about this part?
Thanks
