I shipped my KitchenAid Artisan model #KSM150PSWH and it arrived upside down and oil had spilled everywhere. It works fine, but makes a funny sound now. Any idea where the oil was from and why it would have spilled and what needs to be done? AND if it's a serious problem?
Thank you in advance for any help!
Lora
This kind of unit are lubricated with grase paste. If the unit stays
inactive for a long time, or if the motor and gears are overheating the
grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After
this step, there is need to spread again the grease, using special
foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous
experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users
from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Same thing happened to me.
What type of oil/grease is used to fill it, where is the fill point, and to what level.
Thanks.
The same thing happened to my mixer. What kind of oil do you use, where does it fill, etc.
