SOURCE: My steam mop is spraying
A little bit of duct tape might fix the problem? Or some putty...... Don't burn your leg :)
SOURCE: Water and steam sprays out
The steam comes through that hole, due to clogged/ or blocked line or due to clogged or cracked filter.-------------------------
This hole is a pressure relief valve. The valve is designed to release steam if something is blocking the steam path inside the unit.--------
Try this procedure :---
Using a Phillips head screw driver remove the single screw at the base if the unit and remove
mop head. CAUTION: The spray tip may be hot. Clear any clogs from the spray tip.
Replace mop head back onto unit and tighten screw. Turn unit on. And then check.Is the steam emitting from the same hole still or not.---------
But if its emitting from same hole then try this procedure as follows :----
Remove water tank by lifting straight up and away from unit. Is filter cracked or damaged?--
NOTE: If the filter is blue in color it needs to be replaced. If the filter is not damaged then reinsert the filter back.Dont forget the clean the filter before reinserting.Then refit the filter properly and check,the steam should not blow through that hole.---------
This will help.Thanks.Helpmech.
Here
is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it
may not be getting steam to the head...
Euro-Pro
Shark Steam Mop Problem
Here
also is a link to get any of the Shark
Manuals
that you need.
heatman101
