Jenn-Air JMV9169B Convection/Microwave Oven Logo
Posted on Nov 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jenn-Air JMV9169B top cabinet stencil
I'm having trouble figuring out which areas to cut out for a FLAT bottom cabinet. I'm looking at the stencil. For item "I", Cut out for vertical (outside) exhaust only. This area is shaded and measures 5" x 11-3/4".
In addition, there is a CROSSHATCHED area that says "Cut out slot for smooth flat bottom cabinets only".
I have a Flat bottom cabinet. Do I cut out ONLY the cross hatched area or the entire shaded - cross hatched area? (It showes 6-5/8" to the edge of the cross hatched area then the same 11-3/4".
Also, for item "F", cut out 1-3/4" Diameter for electrical plug. Same thing. This area is shaded and is a circle of 1-3/4" diameter. Immediately above that is another crosshatched area measuring 4" long x 3/4" wide that says "Cut out slot for smooth bottom cabinets only". Again, do I cut out ONLY the cross hatched area or the entire shaded - cross hatched area? (circle and 4" x 3/4" area).
What are these additional areas for???
Thanks for the help.
Dave D.
  • skeeter777 Nov 09, 2008
    Thanks for trying. I appreciate it.
A
Anonymous
Ouch!!
So Customer Service was no help, eh?
William Miller
Level 3:
  • Jenn-Air Master 9,179 Answers
  • Posted on Nov 07, 2008
William Miller
Jenn-Air Master
Level 3:
Answers
9179
Questions
Helped
4481653
Points
21747
I would suggest contacting Jenn-Air / Maytag / Whirlpool customer service on this one.
  • William Miller
    William Miller Nov 09, 2008
    Ouch!! That hurt my ratings....
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Jenn Air Built In Microwave JMC8127DDS - no power to the unit. I've removed all the screws I can see, but can't get the microwave to slide out to see if it is plugged in.
Be advised that they are heavy. You may need 2 people to check this. The bracket may have a lip on the wall section that you have to take the weight off of to move it.
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
The keypad is physically loose and seems to have lost connection. Only the 2 and 7 beep and connect, nothing else works including the vent and light.
well there is a ribbon cable that attaches the key pad to the control board. it will require removing touch panel to examine. if i remember correctly you have to remove the top grill cover usually having 2 or 3 screws.. they will either be hidden inside the luver portion right above the door or actually coming down from the top edge of the microwave... remove the top grill and then you should have a screw holding the console /keypad in place... make sure unit is unplugged while doing all this.. once you get screw out lift strghit up as there are hook latches on this to hold in place and then pull out. check ribbon cable coming from keypad to control board... if that all looks good then you have a bad touch poad and you need to order a new one... usually can locate the parts @
www.sears.com then hit the parts direct link up top of page... it will ask for your model number so have it ready and then in the right box pull down menu and hit model... a parts diagram will come up and pick the area control panel and it will give you a part number and prices as well as availability....good luck to you
My microwave will run, light will come on but it's not heating. The maid was here today and I saw her cleaning it. Could some button have been hit accidentally?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
;0;0;0;0;0;0;0;0;0;0
2helpful
My father's old Jenn-Aire microwave, Model # M170, has a rusted bottom and we need to replace it. Is there a model that is of the same dimensions so that we can replace the unit inside the cabinet above...
You can contact Jenn-Air customer service and they should be able to tell you if there is a "drop-in" replacement for your model.
Crack on Top of Exterior Door - Interior stained
I would STOP useing at once!! Stray microwaves seeping through the crack can be very harmfull to humans and pets! I would call the maker and complain! this is not normal for this to happen unless dropped! (door can be replaced!)
Please rate this response!
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Top Jenn-Air Microwave Ovens Experts
rajanshyam
Level 1 Expert
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
