Jenn-Air JMC8127DD 1000 Watts Microwave Oven
Problems with Jenn-Air JMC8127DD 1000 Watts Microwave Oven?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Jenn-Air JMC8127DD 1000 Watts Microwave...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Jenn-Air JMC8127DD 1000 Watts Microwave Oven RSS Feed
View More Results for Jenn-Air JMC8127DD 1000 Watts Microwave Oven
Questions and Unsolved Support Problems
Unsolved Problems for Jenn-Air JMC8127DD 1000 Watts Microwave Oven RSS Feed
Answer
How in the world do you access the light bulb inside this microwave?  Jenn-Air Customer Service... (More)
Answer
Our Jenn Air microwave JMC8127DD is not working. It appears to have no power. We have turned off the... (More)
Answer
we installed a used Jenn Air microwave that we thought was in good condition (we tested it out... (More)
Answer
Jenn-Air JMC8130DD 1000 Watts Microwave oven. unable to use any function.  Hope you... (More)
Find a Manual
Jenn-Air JMC8127DD 1000 Watts Microwave Oven Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
GRANNY?S NUKE NOTES
Twist the timer knob or push the button and electricity from the wall outlet travels through the power cord and enters the microwave oven through a... written by TheMobilian
This is a test
This is a test test test written by joe123r
Replacing a Turntable Motor on a Microwave
The following advice is for MOST microwave ovens (including over-the-range models). This is a fairly simple repair that can be accomplished without... written by jsrock516
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual. In Whirlpool/Kenmore models this is indicated by a lower case... written by ptishkevich
Microwave works normally but does not heat.
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor, the rectifier diode.or the magnetron. The... written by ginko
Micorwave ovens - and where's the heat?
A microwave not heating up is caused by one or more of the following - 1) Failed controller board (unlikely if you are getting a clock readout and... written by MrMark52
Troubleshooting Guide
Problem: Totally dead oven. Possible causes: No power to outlet (blown fuse or tripped breaker or GFCI). Blown main fuse - likely due... written by sweet_rascal
CHANGE BULB- GE MICROWAVE # JES1289SK01
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I... written by UNCLEMOE
WikiManual
(Post a New Chapter)
How to Clean a Microwave
Splatters of food from microwaving look bad, smell bad, and decrease the efficiency of your microwave. Fortunately, microwaves aren't hard to clean if... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Jenn-Air JMC8127DD 1000 Watts Microwave Oven
Nationwide | 866-240-3413 | Website
When onsite service is not an option you can count on ... Read More
Nationwide | 423-303-3785 | Website
Microwave, blender, mixer parts delivered ove... Read More
Nationwide | 718-584-3449 | Website
Authorized Service center for Saeco, Gaggia, Spi... Read More
Nationwide | | Website
Owner's Manuals and dough kneading paddles for jus... Read More
Rate and Review the Jenn-Air JMC8127DD 1000 Watts Microwave Oven
Write a review:
Rate this product:
Would you recommend the JMC8127DD 1000 Watts Microwave Oven to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Jenn-Air JMC8127DD 1000 Watts Microwave Oven
Key Features
Microwave Type
Built-in
Cooking Power
1000 Watts
Capacity
1.5 cu. ft.
Dimensions
Exterior Depth
20.19 in.
Exterior Height
26.75 in.
Exterior Width
23.5 in.
Jenn-Air Contact Information
Main support number1-800-688-1100
Describe your problem:
Top Microwave Ovens Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
