I have a Copystar CS-3035, and it's fan will not shut off even in sleep mode. Do you know what I can do to turn the fan off or at least slow it down, so it doesn't make so much noise. Thanks in advance for your help.
The fan is rubbing against something or its just noisy... replace it... or remove the obstruction...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Actually fan really works even at sleep mode to exhaust heat, the problem is one of the three fan located at the left side if your facing the machine, is deffective a broken blade causes it to sound bad try to remove its connector, afer all you have two more working
What type of enviorment is the machine in? Is the machine or has the machine been pushed against a wall? Which fan? We need more info please.
