SOURCE: black page
Main charge unit is shorting out.
Pull the main charge unit out of machine.
Take cleaner (included with toner) and clean.
--Look at front and rear for toner build -up on the charge grid.
This build -up causes a short.
After cleaning, reinstall and run.
SOURCE: I brought my copystar 3035 home from my office,
Go to your browser and type in the IP address (I.E. 192.168.1.1) of the copystar into the address bar at the top and you should get a access screen of the copier from there you may have to log in using a password like admin or password it should be at default like a router or something. From there you should find a path to setting up icons that point to shared folders on you local machine or a server.. good luck
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
