Front jet have screws but not the others. Dirt comes out of the others and don't know how to remove to clean them.
I seen two tpyes one where the inter jet unscrew and the other where the outter ring unscrews not sure what kind you have . Went to the pool store and they had a cleaner you add to the water and then run the unit for about 20 minutes then drain . It seem to work pretty good and there was less hassel taking the jets apart
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
SOURCE: my whirlpool bath tub has three jets that work & 3 jets that are
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
SOURCE: Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
SOURCE: Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
