Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
SOURCE: Kohler K1338 spa tub controls messing up
no it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
SOURCE: jets not working
i have seen this in the past, a ground fault electrical outlet on the inside of a roman tub,if you have a 2 story house look for access panel on or by tub. otherwise you have to remove tile or other to access motor, you probably need a step too anyways
SOURCE: We like the eljer sheridan six jet whirlpool tub.
We have not solved our problem,but we will pay a price to find our correct size. We can do it locally for no fee.
SOURCE: Eljer jetted tub on and off switch will not work
It may seem like a dumb answer but check the ground fault outlet or breaker. Then make sure there is enough water in the tub. It should be a few inches over the jets.
SOURCE: My American Standard spa tub Williamsburg Elite
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
