20 Most Recent
American Standard 2294.011.020 Afwall Elongated Wall-ADA Retrofit Toilet Questions & Answers
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
11/15/2017 1:58:53 PM •
American...
Answered
on Nov 15, 2017
Hi, I want to replace
If you go with the 2 bolt you will need (I presume) to drill 2 holes into the tile.
put toilet in place where it will sit and mark the holes , take away toilet and drill the holes with a 7ml tile drill bit (masking tape put over the tile will help you to not slip when starting off the hole). Drill deep enough to insert 7ml rawl plugs. then place the toilet back and fix down with screws long enough to go through the toilet and 3/4 of the rawl plug.
You will need;
Electric percussion drill or descent battery drill.
7 ml tile drill bit
2 x rawl plug 7ml
2 x screw
masking tape is handy
hope this helps,
Alex
5/18/2011 10:39:16 AM •
American...
Answered
on May 18, 2011
Toilet will not flush fast enough
the chain that connects to the flap has too much slack you have to ajust it by switching the chain up a little so the flap will open all the way
1/4/2009 1:05:05 AM •
American...
Answered
on Jan 04, 2009
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
