I don't care how many cleaning solutions are offered. Whirlpool or jacuzzi or jetted tubs -- whatever you call them -- are so gross! Just the thought of bacteria and scum lurking in the jets (even after cleaning) give me the willies. I want the jet holes closed up permanently. We can't afford a new tub. How do we go about doing this? Thanks.
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
SOURCE: some jets dont work
jets don't 'clog' - turn the face of the jet nozzle - it is perhaps an adjustable jet you have that has been turned off.
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
SOURCE: My lasco whirlpool tub leaks scum from the jets do
you need to use a cleaning solution to get the bacteria out of the plumbing lines. suggestions: Jet Cleaner
