You can download a manual for free from the Singer website, link is
http://www.singerco.com/uploads/download/465_7442_efs.pdfjust copy this link into your browser window and give it time to download as its a large pdf file. Once open on your screen, you can click the "clipboard" icon to save the file to somewhere on your PC. Then print it out and either bind up or put pages into a display book so its easy to flip through and stays with the machine.
Just remember to always thread up the top thread with the pressure foot up - this opens up the tension device so the thread can seat it correctly and is something often missed.
Also, use a new needle for each new sewing project, ie about 4-6 sewing hours change the needle and throw out the old one. A blunt needle is often the cause of bad stitching.
All sewing machines, whatever the make, will have similar key parts that are critical to threading up. These will be thread spool holder, the top thread tension device, thread take up lever, a couple of thread guides, the needle bar and needle. Thread in order from the spool down to the needle as per the threading diagram in your manual, ensuring you get the the thread into each thread guide fully, then thread the needle from front to back.
Place the wound bobbin into the bobbin case, it should rotate anticlockwise when you pull the thread tail. Now place the bobbin case into the machine using the latch, and it should lock into place when you let go the latch.
Now hold the top thread tail, wind the balance wheel (big one on the side of the machine) towards you to lower the needle through one stitch sequence so that the needle goes down then back up, now pull the top tail and the bobbin thread should be caught and pulled up to the top of the needle plate. Always hold both threads at the back of the needle plate as you start a new seam to ensure the threads don't get pulled down into the bobbin case/rotary hook area.
