Maytag MDE5500AYW Dryer
ALL service is perfromed from the FRONT. Shock Hazard Warning! Open the dryer door aand remove the screws that hold the door hinges, remove the door, and on the opposite side that have just 2 screws where the door would attach if it was converted to the oppsite opening direction, and remove the front panel. Remove the front bulkhead,(the internal drum opening panel), by removing the 4-5/16" screws that hold it to the outer side panels. Reach back to the rear of the motor and release the tension on the idler and drum belt. Remove the belt and lift drum slightly upward and remove from the unit. You should then observe 2 rollers about 3" in diameter positioned at about 5 and 7 o'clock. The roller at the 5 o'clock position is most likely bound up or not free-rolling. TRU-ARC spring clips,(you may need to purchase), retain the rollers on the shaft and need to be carefully removed and saved for reaasembly. Inspect roller at 7 o'clock for free operation. Purchase what you need and reassemble.
Hope this helps!
