SOURCE: Looking to disable the alarm system for a 1996 Jeep Cherokee Sport
you need to find out which wires go to what like the ones going into the alarm and the ones coming from the car u might have to put them back together..hopefully they are color coordinated for you good luck
SOURCE: 1996 Grand Jeep Cherokee Immobilser/key fob problem
goldie try to lock and unlock the passenger door...there are disarm switches in both doors...the drivers side may have failed but the passenger side may still work...if that dont do it you may need a dealer because the module for the remote keyless entry may have faied
SOURCE: 1996 Jeep Grand Cherokee alarm keeps randomly going off.
Have you had your battery load tested & charging system checked? I'm suspecting your battery is draining down during the night, and if a battery is getting weak, the cold really takes it toll on it. A load test will confirm if battery is weak & testing alternator for charging, will assure that the battery is, or is not getting charged as it should. Having both tested, shouldn't cost much, if not free, especially from a parts supplier that you are considering buying parts as needed from.
SOURCE: 96 jeep grand cherokee. key fob broken... cant start..
Cycle the key in the door lock to disarm a factory alarm.
SOURCE: 2009 Jeep Grand Cherokee Laredo interior lights won't turn on
check your light dimmer & see if you have it set all the way down.If it's anything like my 99WJ it has an off setting when the dimmer is set all the down causing the interior lights to not come on when you open the doors,hope this helps
