Singer 3343 Mechanical Sewing Machine Logo
Denise Reilly Posted on Sep 06, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My machine is locking and apparently tangling up inside of the bobin case
Here's whats going on. I am currently sewing up a cloak made from fleece and faux leather (upholstry variety). I bought a new thread to try out for tougher use and I bought new bobins and that was all I a decided to do differently this time as oposed to all other times I have used this blinking machine. I try to sew a simple seam, just a loooooooong straight line, and I still have problems. These problems manifest themselves as the machine coming to a violent and sudden stop and refusing to advance further. The needle will go up and down, but the fabric will not advance. When I try to remove the fabric I discover that it has been stuck to the machine and have to cut it loose from below with an exacto blade. I then open the bobin case to figure out why there are now several threads coming from it rather than just one and find that those several threads are severed, but on the bobin. As though the bobin had loosened up enough for somebody to make a cut and sever several loops of thread while it was still on the bobin. I clear out the loose threads, re-thread the machine, and move on. It happens apparently randomly too - I will go several passes with no problem, and then lock the machine every 15 freaking stitches. In its earlier incarnation I also had irregular stitches, they kinda looked like this --------u----u--u------u-----u---- it wasnt a scary tangle like I have dealt with before, just odd. I have tried: ALL tension settings from lowest to highest with no effect adjusting stitch length blowing half a can of air through the bobin case and related parts (the machine has been recently serivced in terms of time between use so shouldnt need oiling or anything yet) varying the speed at which I actualy sew the seams changing the bobin out for a different one flipping the thread spool up-side-down (its one of those speels that has a very distinctive bottom, but if you put it right side up the thread pulls from the oposite side that the machine threading instructions wants it to) adding the second spool holder and diverting the thread past that to help keep things from goin' nuts (when it locks, the machine has clearly pulled too much thread and it drapes down from the spool) and at times it loops itself around one of the threading elements a second time as well. so. . . any ideas?
angel dust
Level 2:
Sergeant:
Champion:
  • Expert 240 Answers
  • Posted on Jun 14, 2009
angel dust
Expert
Level 2:
Sergeant:
Champion:
Answers
240
Questions
0
Helped
65467
Points
676
You also need to adjust the pressure foot on the top of the machine. This regulates how much pressure is put on the fabric and the feed. Sounds like it is wrong somehow-maybe you need more pressure. Check the pressure adjustment is screwed in properly if it is this type which unscrews.The pressure adjuster Im reffering to is generally a silver colour and looks a bit like a basic tyre pressure guage or pressure cooker valve-it just got a cuple of lines on it and sits on the top left of the machine above the needle bar. The other thing which could cause problems is the bobbin tension-make sure it is running thru smoothly but not too loose.
2answers
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
The machine sews normally then once in awhile the material gets stuck in one position, does not move. The bobin thread seems to be a bit tangled in the bobbin case. What is going on?
Your bobbin may be wound uneven, try winding a fresh bobbin and make sure that you are using the same weight thread in the top and bottom. And try a fresh needle.
When I sew it only sews about 4 stitches the top thread breaks & sometimes the threads are all tangled in the bobin area. I found a small spring next to a larger spring loose. Where does the little...
You may want to take it to be looked at by a professional if there is a part loose.
I have constant problems with thread breaking and being tangled in the bobbin area with this machine. It can usually be remedied by adjusting your tension. Also, class 15 bobbins stink for this machine (yes, it says they're compatable, but they seem to be 1/8 of an inch too shallow and constaly become unthreaded from the bobbin casing). Try SA 156 metal ones.
1helpful
2answers
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
2helpful
2answers
Model 8280. The thread on the bottom keeps bunching up. It is a horrible mass of thread. Then, it stops moving. Can you help me?
I had the same problem and I tried everything including removing the bobin case, cleaning out lint, changing the needle, adjusting the tension but it did not work. Then I finally tried reloading the bobin thread, making sure to load the bobin according the manual directions....and the problem was solved...no more tangles... just a nice even stitch...yeah!
Tangled thread under metal plate
-The bobbin is too lose. Tight the adjustment screw on the bobbin case a little more and test, keep doing until it's good.
-Or possibly the upper threat is too lose so it won't pulls the bottom up as well.
-Check it out and adjust it.
Good luck
Mai
Bobbin gets tangled up
Try taking the covers off again. Now check under and around the bobin case, thats the black plastic bit that holds the bobin. Look for any fuzz or stray bits of thread inside the machine and and around the feed dogs and under the needle too. I use compressed canned air to get in and really blow everything clean. For some reason if the machine is not totally clean, inside the bobin gets tangled up. If you have had even one knot, odds are parts of it are still floating around inside there somewhere and stopping some little lever from moving and jamming your whole machine. Clean under the bobin case too since lint can left it up and keep the bobin from being perfectly level. Also inspect your bobbin case to make sure it isn't scratched along the edge that rotates back and forth. Even a a tiny scratch will cause it jump its tracks and your bobin will lift up and become jamed. In that case you just have to buy a new bobin case. But most of the time your culprit will be some stray bits of thread or lint.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
