HP iPAQ RX1710 Pocket PC Logo
Posted on Dec 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ITS BEEN A WHILE SINCE I USED MY IPAQ SO I CHARGED IT UP AND TRIED TO TURN IT ON. WHEN IT DID NOT TURN ON I TRIED TO RE BOOT IT BY PRESSING THE STYLUS IN THE SMALL HOLE IN THE BOTTOM OF THE IPAQ. THE MACHINE THEN TURNED ON BUT IT SEEMS TO BE FROZEN ON A PAGE THAT READS HP iPAQ POCKET PC HP INVENT 1.00.05ENG
Larry Ng
Level 3:
Top Expert:
  • HP Master 14,606 Answers
  • Posted on Dec 22, 2017
Larry Ng
HP Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3280825
Points
66651
A 13 year old relic of the past pulled out of the attic or found at a garage sale for 50 cents.?
hp has no support for this, its now a relic retired state there.
some have 2 batteries , one is soldered down. oops.
first google hit.
https://www.youtube.com/watch?v=OpGzA5Xl4J0
google finds then non HP manual , that HP deleted.
here free, give the new batt. 4 hours to charge.
https://www.manualslib.com/products/Hp-Rz1710-Ipaq-Pocket-Pc-2374427.html
RTM?
read page 27 , carefully and the gravity of these words
"Keep the battery charged.
The programs and files you install or create are stored in volatile RAM memory. If the battery
completely discharges, all user-installed programs and user data files
created will be erased and you will have to reinstall them. To prevent
losing valuable programs and files, keep the battery always charged.
Optionally, you can store a limited number of programs and files in the
iPAQ File Store folder so that if the battery completely discharges, they
will not be lost."
the store, is a NVram?, not flash. and the STORE has a battery
what is the chances of any 13year old battery still good.(zero?>)
see the coin cell here, it unplugs other models are soldered down.
ITS BEEN A WHILE SINCE - 1710-0bqeoaofrldpq4t1wllrhfnq-1-0.jpg why spend cash on old relics like this. and labor?
so you learned to day it has 2 batteries not 1
and learned it is 13 year old relic of the past, 100% useless in todays world. (buy notepad new for $50 at walfart)
John B
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 45 Answers
  • Posted on Dec 20, 2017
John B
Expert
Level 2:
New Friend:
Cheetah:
Answers
45
Questions
0
Helped
28307
Points
129
Try replacing the battery. Then try a factory reset.
  • Anonymous Dec 22, 2017
    or the trash like the other million are now.
5 Related Answers
Anonymous
  • 450 Answers
  • Posted on Sep 08, 2005
SOURCE: rx3715 will not recover from a hard reset
try removing the battery - for a few minutes to begin witj, then a few hours if that doesn't help.
Anonymous
  • Posted on Mar 04, 2008
SOURCE: Screen not responding to touch
i had the same problem and figured out that when i put the screen protector on that it got between the housing and the screen and put just enough preasure on the screen it would not let you do anything.if you put your finger on the screen and apply some preasure and then try to use the stylus it will not allow you to .hope this helps someone.
A
Anonymous
  • Posted on Oct 13, 2008
SOURCE: Just a good HP iPAQ hx4700 Disassembly, Screen Removal and Repair guide
Thank you! This is a really good page!
Anonymous
  • 2110 Answers
  • Posted on Feb 08, 2009
SOURCE: i need desktop software for HP iPAQ
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=100773&prodTypeId=215348&prodSeriesId=322908&swLang=8&taskId=135&swEnvOID=1087
here u can find driver..
Anonymous
  • 36 Answers
  • Posted on Mar 09, 2009
SOURCE: hp ipaq 5550
To do a full reset, you hold the calendar and itask buttons (buttons 1 and 4) down at the same time, then insert the stylus into the little hole on the bottom and press gently. Hold all for 4 seconds. The screen should begin to fade. Now release all. If successful, you will not be able to start the machine by pressing the on button. You will have to reconnect to ac power to start it.
That is all there is to it.
My ipaq 214 wont boot up. it just freezes on the HP screen. Ive tried pressing the reset button like over 100 times but it just freezes again. Ive also tried hard reset and that dosent work either. I have...
You could have a corrupted program on your PDA. You need to contact HP and have them re-flash or upgrade the firmware of your PDA and it should work much better than before.
Have a great day!
My phone dosnt turn on
Hi, you need to reset the battery via instructions on http://blogs.unbolt.net/index.php/brinley/2006/08/02/howto_reset_discharged_battery_for_ipaq_6515
IPAQ 210 Stuck on Boot Screen
A "hard" reset work.  I thought I tried this earlier but I was pressing the wrong keys.
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
2answers
IPAQ 3765 Won't Turn On
you may have to buy a new battery for the unit. Simple as that
2answers
Will not come on at all
After a hard reset you must do a soft reset to enable the battery.
Boot screen
Find a way to reset. (manual)
Make sure its full charged too!
IPaq rx3115
I had a similar experience. My device would not charge via the usb charger so I connected it to my wall charger and it charged successfully.
3970 Stuck
Try this, take the ipaq off the cradle, turn the ipaq off (if you can), restart the desktop, put the ipaq back in thc cradle, turn the ipaq on, and restart ROM update again.
3answers
IPAQ 5455 Hard Reset
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
