Panasonic KX-TS3282 Two-line Corded Phone Logo
massie Posted on Feb 23, 2012
Etulisation panasonic kx-ts3282
Le chema de cablage et letulisation
1 Related Answer
Anonymous
  • 1637 Answers
  • Posted on Jan 17, 2011
SOURCE: pas de connexion entre le combine et le support
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
1helpful
Retroillumination an an adidas adh1828 watch
Il y a plusieurs raisons pour lesquelles le voyant vert du r?tro?clairage ne s'allume pas lorsque vous appuyez sur la touche SET/EL. Certaines causes les plus courantes incluent :
  1. Fusible grill? : Le fusible qui alimente le r?tro?clairage peut ?tre grill?, pr?venir ainsi le voyant de s'allumer. V?rifiez le fusible et remplacez-le si n?cessaire.
  2. Probl?me de connexion : Si le voyant ne s'allume pas, cela peut ?tre d? ? un probl?me de connexion ?lectrique entre la touche SET/EL et le circuit de r?tro?clairage. V?rifiez les connexions et sp?cifiez-vous qu'elles sont propres et bien connect?es.
  3. Probl?me de circuit : Si le voyant ne s'allume pas, cela peut ?tre d? ? un probl?me de circuit. Il est possible que le circuit de r?tro?clairage soit d?fectueux ou qu'il y ait une interruption dans le circuit. Il est recommand? de v?rifier les fils et les composants ?lectroniques pour d?tecter tout probl?me.
  4. Probl?me de logiciel : Si le voyant ne s'allume pas, cela peut ?tre d? ? un probl?me de logiciel. Il est possible que le logiciel qui g?re le r?tro?clairage soit d?fectueux ou qu'il y ait un bug qui emp?che le voyant de s'allumer. Il est recommand? de v?rifier les mises ? jour logicielles et de r?initialiser le dispositif si n?cessaire.
Il est important de noter que la r?paration de ces probl?mes peut n?cessiter des comp?tences ?lectroniques et il est recommand? de confier cette t?che ? un professionnel qualifi?.
The intercom on my panasonic kx-T7730 won't turn off, how do I fix this?
La fa?on de d?sactiver l'intercom sur votre t?l?phone Panasonic d?pendra du mod?le exact que vous avez. Voici quelques ?tapes g?n?rales que vous pouvez suivre pour d?sactiver l'interphone :
  1. Appuyez sur le bouton "Menu" ou "Menu principal" sur votre t?l?phone.
  2. Utilisez les touches de navigation pour acc?der aux param?tres de l'intercom. Cela peut ?tre sous l'option "R?glages" ou "Intercom" selon le mod?le.
  3. Utilisez les touches de navigation pour s?lectionner l'option "D?sactiver" ou "Off" pour l'interphone.
  4. Appuyez sur le bouton "OK" ou "Entr?e" pour enregistrer les modifications.
  5. V?rifiez si l'intercom est d?sactiv? en essayant de passer un appel.
Il est important de noter que les ?tapes peuvent varier en fonction du mod?le de t?l?phone et de la version du firmware. Il est recommand? de
Comment entrer dans le mode service de la hisense HA55K3300UWT?
Hisense MSD308PX LCD Television - comment entrer en mode service - comment mettre ? jour le logiciel - panneau de r?tro?clairage LED de 32 pouces
Pour acc?der au menu Factory OSD
une. Avec usine RC (t?l?commande)
1. Appuyez sur le bouton «M» et passez en mode usine. (Note1)
2. Appuyez sur le bouton «Menu» et acc?dez au menu OSD d'usine.
3. Appuyez sur le bouton «CH +» / «CH-» pour s?lectionner le menu de fonction, appuyez sur «VOL +» / «VOL-» pour acc?der au menu de fonction s?lectionn?. Appuyez sur le bouton "VOL +" / "VOL-" pour ajuster les valeurs du menu.
4. Appuyez sur le bouton «M» pour quitter le mode usine dans le menu OSD d'usine.
Lorsque la sortie TV du t?l?viseur est activ?e, l'utilisateur ne peut pas acc?der au menu OSD avec la t?l?commande d'usine
Remarque:
1. Dans le menu "Factory Menu", "Function"> "TOFAC", vous pouvez s?lectionner "M" ou "U", la valeur par d?faut ?tant "U".
- M-Means signifie que vous pouvez entrer en mode usine avec la RC d'usine ou l'utilisateur RC.
- U-Means: vous ne pouvez entrer en mode usine qu'avec la RC de l'utilisateur.
2. Le mode «M» est utilis? uniquement pour la production en usine.
Avec la t?l?commande de l'utilisateur
Allumez le t?l?viseur.
1. Appuyez sur le bouton «Menu» et appelez le menu OSD utilisateur.
2. S?lectionnez «Sound»> «Balance».
3. Appuyez sur la touche num?rique 1> 9> 6> 9 en s?quence lorsque l'?l?ment «Balance» est mis au point.
Remarque: Si n?cessaire, refaites les touches num?riques.
4. L'OSD d'usine appara?t.
Remarque: Appuyez sur le bouton veille, puis sur AC pour ?teindre et red?marrer le t?l?viseur, qui peut quitter le menu OSD d'usine.
Proc?dure de mise ? jour du firmware
Mise ? niveau avec ISP_TOOL
Connexion de mat?riel
Vous pouvez mettre ? jour le logiciel via un outil sp?cial (comme suit)
Connectez la carte de d?bogage au t?l?viseur ? l'aide de l'interface VGA ou du port RS232 (4 broches), l'autre port USB de l'ordinateur.
Installez ISP_TOOL4.5.0.4 ---- uniquement pour la premi?re mise ? jour.
1 Le logiciel est mis ? niveau par un outil de gravure - ISP_TOOL.exe
2 Recherchez le dossier dans lequel se trouve ISP_TOOL4.5.0.4
Il y a trois dossiers / fichiers dans ce dossier ensemble.
DLPORTIO.dll et FTD2XX.DLL doivent ?tre dans le m?me dossier
3 Double-cliquez sur l'ic?ne ISP_TOOL4.5.0.4, puis une fen?tre de dialogue appara?tra comme ci-dessous.
4 Cliquez sur le bouton "Config". Et puis une fen?tre de dialogue appara?tra.
Dessine sur le devant de "Use USB"
Le param?tre Type de port est USB
Le param?tre Addr de base est 0x38C
Adresse esclave ISP choisissez 0x92
Adresse esclave de d?bogage s?rie choisissez 0xB2 ,
5 Cliquez sur le bouton «Connecter» appear si appara?t la figure suivante, cela indique que l'ISP_TOOL est connect? (selon le t?l?viseur, «Type de p?riph?rique» peut ?tre diff?rent.)
Si appara?t la figure suivante , Il indique que l'ISP_TOOL n'est pas connect?. Cliquez s'il vous plait
le bouton "DisCon" et le bouton "Connect" pour se connecter.
6 Cliquez sur le bouton "Lire", choisissez le fichier de mise ? jour correct.
7 Une fois le fichier de mise ? jour s?lectionn? avec succ?s.
Cliquez sur le bouton «Auto» et choisissez les param?tres suivants.
8 Cliquez sur le bouton "Ex?cuter" et attendez la fin de la mise ? jour.
Si vous montrez un message d'erreur alors faites "Dis Con" >> "Connect", et cliquez ? nouveau sur le bouton "Ex?cuter", jusqu'? ce que la fen?tre de dialogue s'affiche.
Mise ? niveau avec le port USB
Le logiciel peut ?tre mis ? jour avec un p?riph?rique USB:
1. Copiez le fichier «* .BIN» tel que «MERGE.BIN» dans le r?pertoire racine d'un disque USB.
2. Ins?rez le disque USB dans la fente USB du t?l?viseur.
3. Appuyez sur le bouton «Menu» et appelez le menu OSD utilisateur, choisissez l'?l?ment «Canal»> «Mise ? jour du logiciel (USB)». (Note 1)
4. Appuyez sur «OK» pour afficher une bo?te de message de confirmation. Appuyez sur le bouton [?] pour s?lectionner «oui» dans la bo?te de message de confirmation, pour lancer la mise ? jour automatique.
5. Ensuite, le logiciel sera automatiquement mis ? jour, [ne pas s'?teindre pendant la mise ? jour].
6. Une fois le logiciel mis ? niveau avec succ?s, TV SET red?marre automatiquement.
Remarque:
1. Dans certains r?glages TV, l'option «Mise ? jour du logiciel (USB)» peut-?tre dans le menu «OPTION».
2. Apr?s la mise ? jour, vous devez confirmer la version du logiciel dans le "Menu Usine" et vous feriez mieux de faire un "Effacement non prot?g?" dans le "Menu Usine"
Power assign:
La puissance a seulement une sortie de + 12V_IN, les autres tensions sont converties de + 12V_IN.
une. 5Vstb est converti par N19 ? partir de + 12V_IN , 5VAIN et 5V_USB sont convertis par N43 ? partir de 5Vstb.
b. 3.3Vstb et 3.3V_mcu comme alimentation de secours pour le mode veille.
c. 3.3V_L'alimentation normale pour N5 et IC principal N46 est convertie par N3 ? partir de 5VAIN; 2.5V_Non alimentation normale pour N46 est convertie par N13 de 5VAIN; L'alimentation VDDC (1,28 V) pour le circuit int?gr? principal (tension de base) est convertie par N1 ? partir de 5 VAIN, tandis que l'alimentation N 1.8 (DDR) est convertie par N15 ? partir de 5 VAIN.
La tension d'alimentation VCC_A pour N17 (amplificateur audio) est convertie par N42 ? partir de + 12V_IN; 5V_Tuner alimentation pour Tuner est converti par N16 ? partir de + 12V; 5V_USB alimente l'interface USB.
f L'alimentation du panneau VCC pour le panneau est convertie par N14 ? partir de + 12V_IN
Signal RF
La fr?quence interm?diaire num?rique et la fr?quence interm?diaire de simulation sont trait?es par le syntoniseur (U42) ? partir du signal RF. Le flux de transport est d?modul? directement par le circuit int?gr? principal ? partir de la fr?quence interm?diaire num?rique, puis saisissez la carte PCMCIA pour d?chiffrer ult?rieurement le circuit int?gr? principal. Le signal interm?diaire de simulation qui a pass? l'amplification et le filtre ? ondes acoustiques de surface pour obtenir une fr?quence interm?diaire entre dans le circuit int?gr? principal. Apr?s traitement par le circuit int?gr? principal, le signal vid?o est ensuite trait? par la sortie SCALER du signal LVDS. Le signal audio est trait? et l'audio amplifi? aux haut-parleurs.
Processus de contr?le:
Le pouvoir
Hisense MSD308PX LCD Television how to enter service mode how to update...
2helpful
6helpful
Bonjour , nous avons un Asko D-3120 j'entend le moteur fonctionner mais rien ne se passe a l'interieur et la lumiere de la tasse avec une assiette clignote sans arrêt . J'ai essayé...
le drain est boucher et la panne de reserve est pleine d'eau solution sort le lave vaisselle de sont emplacement et enleve le panneau arriere ensuite éponge l'eau et débranche le tyau de drain place le tuyau de rain dans un sceau et demarre un cylce de rincage et verifier si il ne coule pas lors du cycle dans la panne
J'ai un 1000 fonte de 79 et je souhaiterais changer l'allumage pour passer sur des vis platinées. J'ai le kit, mais je voudtrais des infos sur le cablage pour evité la boulette...!
Salut, J'en ai un également, avec vis platinées... je peux te filer un coup de main si tu es près de chez moi (77)..... sinon il faut que je retrouve un lien qui explique très bien le changement Laurent
Bonjour ma xbox 360 clignote rouge( 3 LED) et ne fonctionne plus.que faire?et qui contacter en cas de panne? il y a t-il un numéro en france? merci
e74 ou erreur de rrod signifie qu'il y a une issue de matériel. Ce que vous devez faire est une réparation très simple et bon marché. regardez sur ebay pour des kits de réparation de bride de x, ce sont juste quelques mâles et la plupart des vendeurs incluent un bon guide dans la façon faire le mod/difficulté. ce qui cause le rrod ou l'erreur e74 est la bride de forme de X sur le dessous ou le conseil de mère se pliant et mis-formant entraînant la boule soudant sur le gpu/unité centrale de traitement légèrement fondant et formant des fissures de délié dans la soudure. Le kit de x-bride s'appliquera plus de pression au gpu/unité centrale de traitement et tour de déconnecter les ventilateurs et d'allumer le xbox et de lui permettre de surchauffer au sujet de la fonte les joints à rotule de soudure remplira fissures de délié. Selon quel morceau est l'issue vous peut également avoir besoin des 2000 pistolets de chaleur de watt au lieu d'employer la méthode de chauffage finie (le morceau de gpu). Le remplacement des garnitures de la chaleur sur le radiateur par la pâte thermique qui vient avec le kit gardera le refroidisseur du gpu/unité centrale de traitement et vous n'aura pas cette issue encore. Assurez-vous svp que vous achetez le kit qui vient avec les rondelles en nylon soumises à un traitement thermique pendant que les lavages en acier de ressort échouent !. Les prises de réparation environ 1-2 heures J'espère que ceci vous aide dans la fixation xbox J'ai dû utiliser un traducteur d'Internet pour traduire l'anglais au frech ainsi à moi appologise pour n'importe quoi non traduit correctement
L'appareil ne fonctionne plus
Ok, je l'espère, ma traduction est correcte s'il vous plaît ne soyez pas offensé si elle ne l'est pas.
Ce que vous devez faire est de retirer les piles et l'alimentation électrique d'attendre environ 10 à 15 minutes, puis mettez-les en puissance et sur le périphérique.
Qu'est-ce que la marque et le modèle d'appareil est-il?
2answers
Lost driver
salut j'ai un probleme j'ai achete mini DV et le CD et n'est pas installe corectement et je cherche un logiciel s'il vous plait aider moi pour un logiciel de cette mini DV panasonic nv-gs25
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
