Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you need more help with this post a reply
hope this helps you
SOURCE: Pen drive not showing in My Computer
Try to Format it. Its too costy to get it back to life, your pendrive is screwed :(
SOURCE: transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
SOURCE: pen drive detected but unreadable
Has the drive been through any physical trauma - been through a wash cycle in some pocket, been connected through some power disruption, etc - for example)
Does the pendrive open on other machines? If so, you may be able to open and format it there. Other machines mildly can be any other machine, but if that doesn't work, you may want to try a different version of Windows or a mac or linux, etc.
I'm assuming you have a Windows since you say "Drive I"
SOURCE: sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
SOURCE: i cannot format my 64 gb TRANSCEND pendrive
use the mfomat utility software and fornat the pen drive it wil shorly solve u r problem 100%.............
