I have lost the cd to install the cameera on pc
You don't need a cord or special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
SOURCE: i lost my cd , and i need to install CD of olympus FE-310
click the link below and download the drivers for your camera:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1351
SOURCE: how to upload u pic from olympus sp-800uz
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
SOURCE: How can I download the
If you already can connect your camera to your PC, then you should available do download pictures and videos. If you can find your video file from camera suite, open via Windows Explorer.
Camera usually will recognized as Removable Disk. There you can open the folders and browse all of saved files, including picture and video. Video files usually have film-like icon when set in thumbnail or large icon, or just see in detail setting so you can see the file's type.
Hope this help and if you feel this answer helpful, RATE please.
SOURCE: Can you use a haze or UV filter on the Olympus
Yes it is possible with a lens adapter. Search for Kiwiphotos LA-67SP800 or LA-67SP800. Or look at: http://www.kiwifotos.com/Pro_show.asp?Proid=83
On Ebay they can be bought quite cheap. You can fit a filter onto the lens adapter.
