After rebooting the router and modem several times, I can not get the router to recongnize the modem. The RX light is blinking and the one port LAN light is steady. Computer says there is a connection, it appears it is just not getting the IP address.
When connecting directly from the modem to the computer everything works fine.
Any suggestions on how to make this router work>
Check you computer program, you should have the Sonicwall soho wizard program, if not try to fund the CD and run it.
turn off all devices, turn on one device one at a time starting with modem, router and pc. the wizard should come up for the sonic wall , just folow the wizard instruction.
It seems your router is going bad , first thing to do here is to reset the router by pressing the reset button for 30 seconds and after the reset unplug the power of the router for 10 seconds and then if you still have the setup CD for the router just run it to the computer conencted to the router and reconfigure the router back....
Sonic Wall SOHO 50
Server is Comcast
what maek and model is the router????
who i syour IPS???
