Kenmore Elite 45986 Front Load Washer Logo
Posted on Oct 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Font loader washer water does'nt shut off
Kenmore elite front loader 11044832200
the water keeps dripping in the tub after i shut the washer off
  • Anonymous Mar 18, 2014
    kenmore model 82870820 drips cold water in to the tub when off
  • Anonymous Mar 19, 2014
    water dripping in washer when shut off
Anonymous
Level 3:
Genius:
  • Master 1,028 Answers
  • Posted on Oct 25, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1028
Questions
Helped
316779
Points
2631
Remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
1helpful
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
3helpful
Kenmore front loader tub fills with water when not in use
your water fill valves are leaking severely,you should see water dripping in there all the time if its this bad and your clothes should still be wet,not damp even after a good spin after the final spin
1helpful
2answers
Can you use regular detergent with front loader washers??
All manufactures suggest using a high efficiecy detergent. They are specially formulated to keep the suds level low and work well with the low water levels of a front loader. Boxes are marked with an HE on them letting you know they are for high effiency machines. Regular detergents were designed for washers that use many gallons of water.
3helpful
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
1helpful
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Didn't start washer, but there is water in the tub!!
I had similar problems. If there is no power, first try to unplug the washer for five minutes and then plug it back in. If there is still no power, unplug the washer, unscrew the back panel and make sure the white and black wires, coming from the power cord, did not come loose or are disconnected. If the door is locked shut, open the bottom panel. If you reach way up by where the door latches, there is a little tab you can pull down to open it. Also, you may want to check the filter. There is a big round cap, where the tub drains into before it reaches the pump. Unscrew it, but have a wet/dry vac ready to **** up any water remaining while you open it. Clean the filter and then screw it back in.
1helpful
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
6helpful
2answers
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Alexander
vince
