1991 Lincoln Town Car Logo
Posted on Feb 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Running hot replace therostat and radiator and hoses, and it runs hot after driving for 5 min
raj somaiya
Level 3:
  • Lincoln Master 5,370 Answers
  • Posted on Feb 09, 2012
raj somaiya
Lincoln Master
Level 3:
Answers
5370
Questions
0
Helped
3571127
Points
14579
For car running hot problem,i suggest you to click this link below and follow the troubleshooting procedure:-----http://technoanswers.blogspot.in/2012/02/car-running-hot.html
-----------Thanks.
3 Related Answers
Jared Gross
  • 7 Answers
  • Posted on Nov 22, 2011
SOURCE: My 2004 lincoln lx runs hot I have replaced the thermostat, hoses and it continues to use antifreeze and runs hot, Some days it won,t run hot at all what could be the problem ?
It sounds to me like a waterpump. You can check it by wiggling the pump pulley or start the motor and watch if the pump pully has any side to side movement, if so then it is bad
Anonymous
  • 106 Answers
  • Posted on Aug 03, 2009
SOURCE: My car has had the radiator and the hoses replace
check to be sure cooling fans work and also possible bad thermostat
Anonymous
  • 11896 Answers
  • Posted on Sep 19, 2010
SOURCE: My 1996 lincoln towncar radiator
sounds like your thermostat needs to be replaced. Make sure their is no air in the system, just coolant that is a 50/50 water/antifreeze mix.
2answers
98 chevy cavalier...water is boiling out of the overflow lid...it is plastic and that is where the radiator cap is. car runs hot, and water is gone when i get home...15 min commute. fill it up and...
sounds like it's time to take it to the shop and change head gasket if head is still good ! every time it gets hot it warps it, prob. need new head too !
93 nissan quest overheats
i would replace thermostat and also check to see if fan motor is running. Best way to check fan is to turn on the defrost and fan should kick on. flushing radiator would help and also check for leaks in the coolant system. hoses,heater core,waterpump. Hope this help and good luck
2helpful
4answers
I have a 92 accord LX. I have replaced the Radiator and the hoses, thermostat and fan switch. Car is still reading hot in a matter of 5 to 10 mins of running. Fluids are topped off. I am not sure why it is...
If you have no air in the system, cooling fans & water pump are working properly, and you didn't install the thermostat backwards, you could have a head gasket problem. Also, make sure the gauge is reading correctly, and the engine is actually hot & the gauge is not giving you a false reading.
If you installed the thermostat upside down, it will not open to allow coolant to circulate. This 5-10 minute time frame you give points to a water pump or thermostat.
I hope this helps.
How to change the therostat in 1985 chevy ca[rice?
the thermostat is in the housing where the top radiator hose connects to the engine !!!!
1. remove the top radiator hose from the housing
2. remove the bolts that hold the housing together ( be careful NOT to break them off )
3. remove the old thermostat
4. remove the old gasket with a suitable scraper & clean both surfaces of the housing with the scraper or sandpaper
5. fit the new thermostat & new gasket
6. put the housing back together & replace the bolts being careful not to over tighten
7.replace top radiator hose & tighten clamp & fill radiator with water
8. start engine & run to reach normal running temperature & check for leaks
hope this helps......cheers.
2answers
Car till goetting to hot
you might need to add water to your radiator
Engine running hot. Water in radiator is not circulating
sounds like you need to replace the therostat
Running hot
replace the therostat ( most likely )
and the radiator cap
2helpful
3answers
Car over heating
1)check coolant level if low ,check for leaks,examine all hoses for cracks and wear also chek thermostat housing for leaks,if no leaks. 2)when engine is hot use your hand to check temp. of upper hose if hose is cool replace the therostat. also make sure the cooling fan runs when engine gets warm. otherwise bad water pump drive belt or belt not adjusted correctly,ignition timing incorrect,radiator core blocked(flush&fill) of radiator grill dirty, radiator cap not maintaining proper preassure(have it pressure check at a shop) good luck
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
