tThe diagnostic circuits is shutting your TV down. In most cases the set will shut it down immediately. Apparently your set hasn't shut completely down yet. When you turn your TV on the diagnostic circuits send a low voltage, low frequency signal through all the circuits and depending on how they come back whether the sets powers up to full power. If a problem is detected it will shut down to protect the other circuits. It sounds like you might have some capacitors going bad on your power board. A capacitor that is going bad would let it come on for a few seconds then the diagnostic circuits would see the capacitor getting further out of tolerance and shut the set down. If you are a DYS type person you might want to lay it flat of it;s face and remove the back. A bad capacitor will be bulged out on the top. are Replace capacitors with the exact uf value and if you can go above the rated voltage but never below., If this isn't the problem then it is probably the main board (the board where your cable hooks up to), There are other things that cab causes for this but I would check the capacitors first.
Col. Dana Gillespie
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Machine shuts down after 6 seconds...
Answer
Failed: retry
DVD/VCR Combo was working fine then one day machine started
shutting down after a few seconds of...
(More)(More)
shutting down after a few seconds of operation. It happens with both, a
VCR and a DVD. I can watch 6 secs. of a movie at a time.
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualifiedservice tech take a lookbecause there are too many things that could be the root cause.
Sounds like the lamp to me. The projection lamps get hotter as
they age and the TVs have a sensor to monitor the temp and shutdown the
TV if it get too high
Projection TV makers charge an arm and a leg for their replacement
lamps. They make it easy to do but as a result the custom lamp
assy is expensive. The trick is to buy just the bulb for your
model TV from any number of us aftermarket sources at a fraction of the
lamp price and install it in the old lamp yourself. Really
easy.
