The dishwasher overflowed and last time repair man said that a breaker makes it so it will only drain which is what I think is happening again. What do you think and how do I get to it? Alice
The Bosch dishwasher has a logic system for the event of a leak. there is a float in the pan under the dishwasher. If any debris gets under the float and it cannot return to normal position. The dishwasher will not fill and only drain. The solution is to take off the toe kick plate and look with a flashlight on the left side. There is a depression and a styrofoam float, a narrow vacuum can be used to vacuum any debris from under the float. If there is no debris then the switch is stuck and requires replacement about $30.00 for the part but requires removal and partial disassembly of the dishwasher. I bet the problem is debris under the float. I hope this helps.
Also...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
