Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Anonymous Posted on Oct 18, 2008
WD-52525 air filter cover open error 33, FD connector?
I just replaced the caps on the boards in my Mitsubishi WD-52525. After getting it together I realized FD was not connected. I can't remember or find where FD connector goes which I believe is the Filter Detect switch and is causing my error 33. Can anyone help? Thanks
Anonymous
Level 1:
  • Contributor 18 Answers
  • Posted on Aug 23, 2009
Anonymous
Contributor
Level 1:
Answers
18
Questions
Helped
100138
Points
37
Connector locared on filter cover . back of metal filter .....
very small conector ........
Own a mitsubishi WD-52525 52 in. Rear Projection HD TV. Already been through the "blinking light of death" problem about 2 yrs. ago. Now have a steady red lamp light. Purchased new lamp, installed, and...
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. sounds like caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use the table below -
You can buy replacement caps from Mouser electronics online
1helpful
I've replace the lamp and capasitors, now I'm getting two codes. 4 1 and 3 3
The 33 error means the air filter cover is open. The 41 error means a short is detected.
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
1helpful
Mitsubishi WD 52525 lamp replaced, no picture, red light
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
RE: Mitsubishi 52525 still green light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
1helpful
2answers
Mitsubishi WD-62525 DLP has no picture
Mits WD 52525 format issue.
2answers
Flashing green light
Wd 52525 error code 34 lamp abnomality
the capictor problem is mostly for WS models
you can locate the dm model from this link
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
